Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
  1. Shut down the laptop and disconnect the power cord
    • Shut down the laptop and disconnect the power cord
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over
  2. Remove the (6) visible 10mm T-7 screws Remove the (4) visible 6mm T-7 screws Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws
    • Remove the (6) visible 10mm T-7 screws
    • Remove the (4) visible 6mm T-7 screws
    • Use the blue plastic opening tool to carefully remove the rubber pad which covers the two remaining screws
    • Remove the remaining (2) 10mm T-7 screws
  3. Carefully lift the cover upwards
    • Carefully lift the cover upwards
    • If the cover seems stuck use a spudger tool to pry the sides
  4. Locate the clip attaching the right-side speakers to the motherboard. Carefully pull on the clip until it detaches from the motherboard.
    • Locate the clip attaching the right-side speakers to the motherboard.
    • Carefully pull on the clip until it detaches from the motherboard.
    • Use a plastic opening tool if needed.
  5. Remove the two 3.5mm #00 Phillips screws which hold the speaker in place. Carefully lift the right-side speaker assembly away from the motherboard.
    • Remove the two 3.5mm #00 Phillips screws which hold the speaker in place.
    • Carefully lift the right-side speaker assembly away from the motherboard.
  6. Locate the clip attaching the left-side speakers to the motherboard. Carefully pull on the clip until it detaches from the motherboard.
    • Locate the clip attaching the left-side speakers to the motherboard.
  7. Remove the two 3.5mm #00 Phillips screws which hold the speaker in place. Carefully lift the left-side speaker assembly away from the motherboard.
    • Carefully lift the left-side speaker assembly away from the motherboard.
Conclusión
Andrew Rodiek
Miembro Desde 13/01/15
553 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-4, Hickman Winter 2015 Miembro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 447
