Saltar al contenido principal
Acer Aspire R7 AC Socket Replacement
Qué necesitas
  1. Acer Aspire R7 AC Socket Replacement, Cover: paso 1, imagen 1 de 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 AC Socket Replacement: paso 2, imagen 1 de 3 Acer Aspire R7 AC Socket Replacement: paso 2, imagen 2 de 3 Acer Aspire R7 AC Socket Replacement: paso 2, imagen 3 de 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 AC Socket Replacement: paso 3, imagen 1 de 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 AC Socket Replacement, AC Socket: paso 4, imagen 1 de 3 Acer Aspire R7 AC Socket Replacement, AC Socket: paso 4, imagen 2 de 3 Acer Aspire R7 AC Socket Replacement, AC Socket: paso 4, imagen 3 de 3
    • Locate the AC Socket ribbon connector
    • Loosen the ribbon connector using the plastic opening tool
    • Pull the ribbon connector away from the motherboard
  5. Acer Aspire R7 AC Socket Replacement: paso 5, imagen 1 de 2 Acer Aspire R7 AC Socket Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
    • There is two sided tape holding this component to the case
    • Once the tape on the Socket is loose, pull up and away from the case to remove it.
Conclusión
Una persona más ha completado esta guía.
Andrew Rodiek
Miembro Desde 01/13/15
601 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-4, Hickman Winter 2015 Miembro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,399
