Saltar al contenido principal
Introducción
This guide will show the reader how to replace the fan in their Acer Aspire R5-571T-59DC.
It may be necessary to replace this component if the laptop constantly overheats, the fan makes strange noises while spinning or won't spin at all.
Please be gentle while installing the new fan in the device so as to not damage the motherboard or the new fan. Computers fans can be very touchy and may become unbalanced if dropped or heavily jolted.
  1. Disconnect all power from the laptop and turn over so the bottom is facing you. Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard. Lift the battery out of the case. Lift the battery out of the case.
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Remove the seven 0.7mm Phillips #00 screws securing the fan in place.
    • Remove the seven 0.7mm Phillips #00 screws securing the fan in place.
  4. Unplug fan from motherboard.
    • Unplug fan from motherboard.
    • Lift and remove fan from case.
Conclusión
Una persona más ha completado esta guía.
Jakobi Peets
Miembro Desde 25/01/18
245 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S20-G2, Passmore Spring 2018 Miembro de USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 26
Todo El Tiempo: 474
