Saltar al contenido principal
Acer Aspire R5-571T-59DC Battery Replacement
Qué necesitas
  1. Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: paso 1, imagen 1 de 2 Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: paso 1, imagen 2 de 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Battery Replacement, Battery: paso 2, imagen 1 de 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: paso 2, imagen 2 de 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: paso 2, imagen 3 de 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
Conclusión
Una persona más ha completado esta guía.
Kelly Johnston
Miembro Desde 01/25/18
600 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S20-G2, Passmore Spring 2018 Miembro de USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Miembros
7 Guías creadas
Un comentario
This seems to be the correct battery for the replacement, judging by the above photos, the AC14B3K
Acer AC14B3K, AC14B8J, and AC14B8K Laptop Battery
I plan to try this repair myself soon.
Sean Anderson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 23
Todo El Tiempo: 5,083
