Introducción
You might need to replace your hard drive if you need to boost up your computer speed or to increase the storage capacity. It could also be needed just to replace a failing hard drive, either way it goes, this particular guide will carefully and clearly walk you through the necessary steps needed to accomplish your goal in replacing the hard drive in your computer.
Qué necesitas
Power down the laptop and make sure that it is turned off.
Flip the laptop over so that the back side of the laptop is facing you.
Una persona más ha completado esta guía.
