Saltar al contenido principal
Acer Aspire R5-471T-52EE Motherboard Replacement
Qué necesitas
  1. Acer Aspire R5-471T-52EE Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Acer Aspire R5-471T-52EE Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Motherboard Replacement: paso 2, imagen 1 de 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Remove seven 3 mm screws using the Phillips #00 screwdriver.
  4. Acer Aspire R5-471T-52EE Motherboard Replacement: paso 4, imagen 1 de 1
    • Once the screws are removed, disconnect seven plugs from the motherboard.
    • Keep in mind that a majority of these wires are extremely thin and fragile. Disconnect them with light force and care.
  5. Acer Aspire R5-471T-52EE Motherboard Replacement: paso 5, imagen 1 de 1
    • Flip up the small black portion the connectors are connected to and disconnect them from the motherboard.
    • Grab the yellow piece of tape to easily remove the connection from the motherboard with nothing more than some gentle force.
    • Remove the large black ribbon wire by gently pulling on the white tab towards yourself.
    • Remove the large white ribbon wire by pulling up on the small black tab.
  6. Acer Aspire R5-471T-52EE Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the four remaining screws located on the fan using the Phillips #00 screwdriver.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 17
Todo El Tiempo: 586
