Saltar al contenido principal
Acer Aspire R5-471T-52EE Battery Replacement
Qué necesitas
  1. Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Battery Replacement: paso 2, imagen 1 de 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 1,035
