Introducción
Here is a guide that will help you remove the dead battery from the laptop and replace it with a new one. Tools you will need to are a PH0 sized Phillips screwdriver, an anti-static wrist strap and a metal spudger.
Qué necesitas
Flip the laptop on to its front, so that the back is facing up
Unscrew the twelve 19.05 mm PH#0 screws.
Herramienta utilizada en este paso:Anti-Static Wrist Strap$7.95
Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
3 personas más completaron esta guía.
2 comentarios
Nicely done manual, however share your thoughts, my ‘puter showed critical battery, I replaced an original AC14B3K with a Flyten AC14B8K battery and I have -0- lights/power. What are your thoughts?
