Saltar al contenido principal
Acer Aspire One ZG5 Wireless Card Replacement
Qué necesitas
  1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: paso 4, imagen 1 de 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Wireless Card Replacement: paso 6, imagen 1 de 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Wireless Card Replacement: paso 7, imagen 1 de 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Wireless Card Replacement: paso 8, imagen 1 de 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
Conclusión
8 personas más completaron esta guía.
Doug Gallatin
Miembro Desde 10/05/10
6,337 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 7-49, Amido Fall 2010 Miembro de Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Miembros
27 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 21
Todo El Tiempo: 23,536
