Saltar al contenido principal
Acer Aspire One ZG5 Keyboard Replacement
Qué necesitas
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: paso 2, imagen 1 de 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: paso 3, imagen 1 de 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: paso 5, imagen 1 de 3 Acer Aspire One ZG5 Keyboard Replacement: paso 5, imagen 2 de 3 Acer Aspire One ZG5 Keyboard Replacement: paso 5, imagen 3 de 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: paso 6, imagen 1 de 2 Acer Aspire One ZG5 Keyboard Replacement: paso 6, imagen 2 de 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: paso 7, imagen 1 de 2 Acer Aspire One ZG5 Keyboard Replacement: paso 7, imagen 2 de 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
Conclusión
12 personas más completaron esta guía.
Doug Gallatin
Miembro Desde 10/05/10
6,337 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 7-49, Amido Fall 2010 Miembro de Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Miembros
27 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 24,623
