Saltar al contenido principal
Acer Aspire One ZG5 Fan Replacement
Qué necesitas
  1. Acer Aspire One ZG5 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Fan Replacement: paso 2, imagen 1 de 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Fan Replacement: paso 3, imagen 1 de 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Fan Replacement, Wireless Card: paso 4, imagen 1 de 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Fan Replacement: paso 5, imagen 1 de 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Fan Replacement: paso 6, imagen 1 de 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Fan Replacement: paso 7, imagen 1 de 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Fan Replacement: paso 8, imagen 1 de 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Acer Aspire One ZG5 Fan Replacement, Keyboard: paso 9, imagen 1 de 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Fan Replacement: paso 10, imagen 1 de 3 Acer Aspire One ZG5 Fan Replacement: paso 10, imagen 2 de 3 Acer Aspire One ZG5 Fan Replacement: paso 10, imagen 3 de 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Fan Replacement: paso 11, imagen 1 de 2 Acer Aspire One ZG5 Fan Replacement: paso 11, imagen 2 de 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Fan Replacement: paso 12, imagen 1 de 2 Acer Aspire One ZG5 Fan Replacement: paso 12, imagen 2 de 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  13. Acer Aspire One ZG5 Fan Replacement, Top Case: paso 13, imagen 1 de 1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Fan Replacement: paso 14, imagen 1 de 2 Acer Aspire One ZG5 Fan Replacement: paso 14, imagen 2 de 2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Fan Replacement: paso 15, imagen 1 de 1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Fan Replacement: paso 16, imagen 1 de 3 Acer Aspire One ZG5 Fan Replacement: paso 16, imagen 2 de 3 Acer Aspire One ZG5 Fan Replacement: paso 16, imagen 3 de 3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Fan Replacement: paso 17, imagen 1 de 2 Acer Aspire One ZG5 Fan Replacement: paso 17, imagen 2 de 2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Fan Replacement: paso 18, imagen 1 de 2 Acer Aspire One ZG5 Fan Replacement: paso 18, imagen 2 de 2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Fan Replacement, Internal Wireless Card: paso 19, imagen 1 de 1
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Fan Replacement: paso 20, imagen 1 de 1
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Fan Replacement: paso 21, imagen 1 de 1
    • Gently pull the wireless card to the right and slide it out of its socket.
  22. Acer Aspire One ZG5 Fan Replacement, Motherboard: paso 22, imagen 1 de 1
    • Disconnect the display cable from the top left of the motherboard.
  23. Acer Aspire One ZG5 Fan Replacement: paso 23, imagen 1 de 2 Acer Aspire One ZG5 Fan Replacement: paso 23, imagen 2 de 2
    • Disconnect the speaker cable from its socket on the motherboard.
  24. Acer Aspire One ZG5 Fan Replacement: paso 24, imagen 1 de 1
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
  25. Acer Aspire One ZG5 Fan Replacement: paso 25, imagen 1 de 1
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  26. Acer Aspire One ZG5 Fan Replacement: paso 26, imagen 1 de 1
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
  27. Acer Aspire One ZG5 Fan Replacement: paso 27, imagen 1 de 1
    • Lift the entire motherboard assembly out the case.
  28. Acer Aspire One ZG5 Fan Replacement, Fan: paso 28, imagen 1 de 2 Acer Aspire One ZG5 Fan Replacement, Fan: paso 28, imagen 2 de 2
    • Disconnect the fan cable from the motherboard.
  29. Acer Aspire One ZG5 Fan Replacement: paso 29, imagen 1 de 1
    • Remove the three 3.9mm screws using Phillips #1 screwdriver.
  30. Acer Aspire One ZG5 Fan Replacement: paso 30, imagen 1 de 1
    • Lift the fan housing from the motherboard.
Conclusión
10 personas más completaron esta guía.
Doug Gallatin
Miembro Desde 10/05/10
6,337 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 7-49, Amido Fall 2010 Miembro de Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Miembros
27 Guías creadas
4 comentarios
Steps 4~8 show to remove the wireless card from its access panel outside the computer, then steps 19~21 show to remove it from the inside once the case is off.
Redundant?
I drink beer - Contestar
There are two wireless cards -- for that exact model it looks like bluetooth and 802.11n but different models may be different
nathan -
I couldn't ask for it to be any easier. Great job.
Ron Price - Contestar
The page layout is good.well done job.thanks for providing the repairing information about Acer aspire one.it is the very interesting web page.http://djnni.com
belly william - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 50
Todo El Tiempo: 27,582
