Saltar al contenido principal
Acer Aspire One D255E RAM Replacement
Qué necesitas
  1. Acer Aspire One D255E RAM Replacement, Keyboard: paso 1, imagen 1 de 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E RAM Replacement: paso 2, imagen 1 de 2 Acer Aspire One D255E RAM Replacement: paso 2, imagen 2 de 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E RAM Replacement: paso 3, imagen 1 de 3 Acer Aspire One D255E RAM Replacement: paso 3, imagen 2 de 3 Acer Aspire One D255E RAM Replacement: paso 3, imagen 3 de 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E RAM Replacement: paso 4, imagen 1 de 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E RAM Replacement, Back Panel: paso 5, imagen 1 de 2 Acer Aspire One D255E RAM Replacement, Back Panel: paso 5, imagen 2 de 2
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E RAM Replacement: paso 6, imagen 1 de 2 Acer Aspire One D255E RAM Replacement: paso 6, imagen 2 de 2
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E RAM Replacement: paso 7, imagen 1 de 3 Acer Aspire One D255E RAM Replacement: paso 7, imagen 2 de 3 Acer Aspire One D255E RAM Replacement: paso 7, imagen 3 de 3
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E RAM Replacement, RAM: paso 8, imagen 1 de 3 Acer Aspire One D255E RAM Replacement, RAM: paso 8, imagen 2 de 3 Acer Aspire One D255E RAM Replacement, RAM: paso 8, imagen 3 de 3
    • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
    • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
Conclusión
7 personas más completaron esta guía.
Brian
Miembro Desde 03/19/16
1,302 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Miembro de UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
Miembros de 2
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 37
Todo El Tiempo: 4,743
