Saltar al contenido principal
Acer Aspire One D225-1625 Wireless Card Replacement
Qué necesitas
  1. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: paso 1, imagen 1 de 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: paso 1, imagen 2 de 3 Acer Aspire One D225-1625 Wireless Card Replacement, Battery: paso 1, imagen 3 de 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D225-1625 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: paso 3, imagen 1 de 2 Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: paso 3, imagen 2 de 2
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel and slide back and forth across the edge until the back gently pops off.
  4. Acer Aspire One D225-1625 Wireless Card Replacement: paso 4, imagen 1 de 2 Acer Aspire One D225-1625 Wireless Card Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to disconnect the black and white wires from the wireless card by pulling them up off the card.
  5. Acer Aspire One D225-1625 Wireless Card Replacement: paso 5, imagen 1 de 2 Acer Aspire One D225-1625 Wireless Card Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the top right screw on the wireless card.
    • Pull out wireless card by sliding it out to your right.
Conclusión
Un comentario
Awesome I changed wireless card with your instruction this is a helpful 👍👍
sohil shekh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 437
