Saltar al contenido principal
Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement
Qué necesitas
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Remove eleven 4 mm Phillips #1 screws.
    • Gently remove the back lid.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement: paso 2, imagen 1 de 1
    • Once the panel is removed, you will see two speakers that is attached to the motherboard by a black cord.
    • Pull the cord gently to remove, you may have to wiggle the cord if it does not come out smoothly.
    • Repeat the process to remove the other cord.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Speakers Replacement: paso 3, imagen 1 de 1
    • Pull upwards to remove the speaker.
    • Repeat the process to remove the second speaker.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 145
