Introducción
The Wifi card allows the user to connect to a wireless network. This guide will show you how to remove and replace the Wifi card in this laptop.
Partes
No se requieren partes.
  1. Remove the ten 7mm Phillips #0 screws from the bottom. Remove the ten 7mm Phillips #0 screws from the bottom.
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release. Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Disconnect the two antenna cables from the Wi-Fi card. Disconnect the two antenna cables from the Wi-Fi card.
    • Disconnect the two antenna cables from the Wi-Fi card.
  5. Remove the single 5mm Phillips #0 screw from the Wi-Fi card. Remove the single 5mm Phillips #0 screw from the Wi-Fi card.
    • Remove the single 5mm Phillips #0 screw from the Wi-Fi card.
  6. Slide out the Wifi card from its slot by pulling parallel to the board. Slide out the Wifi card from its slot by pulling parallel to the board.
    • Slide out the Wifi card from its slot by pulling parallel to the board.
Conclusión
Joseph
Miembro Desde 25/01/18
589 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S20-G1, Passmore Spring 2018 Miembro de USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 134
