Saltar al contenido principal
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement
Qué necesitas
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: paso 1, imagen 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 2, imagen 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 2, imagen 2 de 2
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: paso 3, imagen 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 4, imagen 1 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 4, imagen 2 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 4, imagen 3 de 3
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 5, imagen 1 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 5, imagen 2 de 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 5, imagen 3 de 3
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  6. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: paso 6, imagen 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: paso 6, imagen 2 de 2
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  7. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 7, imagen 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 7, imagen 2 de 2
    • Disconnect the two antenna cables from the Wi-fi card.
  8. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 8, imagen 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 8, imagen 2 de 2
    • Disconnect the display cable by pulling it down and towards you.
  9. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 9, imagen 1 de 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 9, imagen 2 de 2
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  10. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: paso 10, imagen 1 de 1
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
Conclusión
Una persona más ha completado esta guía.
Joseph
Miembro Desde 01/25/18
685 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S20-G1, Passmore Spring 2018 Miembro de USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 1,617
