Introducción
A dysfunctional hard drive can completely ruin the life of an otherwise functional computer; therefore, if any problems arise regarding the hard drive, it should be fixed or replaced. Removing the hard drive requires the battery and back cover to be removed and then only a few screws need to be removed to completely take out the hard drive.
Qué necesitas
Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
Locate the single 6 mm Phillips screw in the lower middle of the back plate.
Remove the screw using a Phillips #0 Screwdriver.
Locate the four 6 mm Phillips screws pictured necessary to remove the hard drive.
Remove all four of the screws using a Phillips #0 Screwdriver.
3 personas más completaron esta guía.
