Saltar al contenido principal
Acer Aspire One A150-1672 Front-facing Camera Replacement
Qué necesitas
  1. Acer Aspire One A150-1672 Front-facing Camera Replacement, Front-facing Camera: paso 1, imagen 1 de 2 Acer Aspire One A150-1672 Front-facing Camera Replacement, Front-facing Camera: paso 1, imagen 2 de 2
    • With your fingers, remove 6 rubber coverings located at the edges of screen. The rubber coverings are held in place with a small amount of adhesive, but you should be able to peel them off easily.
    • There are 4 coverings on the top (circular shaped) and 2 on the bottom (half-oval shaped).
  2. Acer Aspire One A150-1672 Front-facing Camera Replacement: paso 2, imagen 1 de 2 Acer Aspire One A150-1672 Front-facing Camera Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the six 5.2mm screws in the places where the rubber coverings were located.
  3. Acer Aspire One A150-1672 Front-facing Camera Replacement: paso 3, imagen 1 de 2 Acer Aspire One A150-1672 Front-facing Camera Replacement: paso 3, imagen 2 de 2
    • Slide the spudger between the thin gap located between the white and pink plastic casing at the top.
    • Move the spudger from the right side to the left to detach the white plastic frame from the pink plastic casing.
    • Remove the white frame by pulling it towards yourself.
    • It may take considerable force to initially slide the spudger between the white and pink parts of the casing.
  4. Acer Aspire One A150-1672 Front-facing Camera Replacement: paso 4, imagen 1 de 1
    • At the top of the display screen, pull the brown connector towards the right with your right hand while holding on to the black piece of electrical tape next to the white connector with your left hand to disconnect the two connectors from each other.
    • Gently pull the display screen towards you to more easily access the cable behind the screen.
  5. Acer Aspire One A150-1672 Front-facing Camera Replacement: paso 5, imagen 1 de 2 Acer Aspire One A150-1672 Front-facing Camera Replacement: paso 5, imagen 2 de 2
    • Use the spudger to detach the piece of tape from the camera by sliding it between the camera and tape.
    • Pull the camera towards you to remove it.
Conclusión
Connor Watkins
Miembro Desde 10/30/16
261 Reputación
2 Guías creadas
Equipo
Baylor, Team 4-3, Williams Fall 2016 Miembro de Baylor, Team 4-3, Williams Fall 2016
BU-WILLIAMS-F16S4G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 356
