Saltar al contenido principal
Acer Aspire One A150-1570 Keyboard Replacement
Qué necesitas
  1. Acer Aspire One A150-1570 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Keyboard Replacement: paso 2, imagen 1 de 2 Acer Aspire One A150-1570 Keyboard Replacement: paso 2, imagen 2 de 2
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Keyboard Replacement: paso 3, imagen 1 de 2 Acer Aspire One A150-1570 Keyboard Replacement: paso 3, imagen 2 de 2
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Keyboard Replacement: paso 4, imagen 1 de 3 Acer Aspire One A150-1570 Keyboard Replacement: paso 4, imagen 2 de 3 Acer Aspire One A150-1570 Keyboard Replacement: paso 4, imagen 3 de 3
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Keyboard Replacement: paso 5, imagen 1 de 3 Acer Aspire One A150-1570 Keyboard Replacement: paso 5, imagen 2 de 3 Acer Aspire One A150-1570 Keyboard Replacement: paso 5, imagen 3 de 3
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
Conclusión
2 personas más completaron esta guía.
Blue
Miembro Desde 10/10/16
124 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 412
