Saltar al contenido principal
Acer Aspire One 751h-1948 RAM Card Replacement
Qué necesitas
  1. Acer Aspire One 751h-1948 RAM Card Replacement, RAM Card: paso 1, imagen 1 de 1
    • Below the battery to the right corner of the laptop the RAM card will be located there.
  2. Acer Aspire One 751h-1948 RAM Card Replacement: paso 2, imagen 1 de 3 Acer Aspire One 751h-1948 RAM Card Replacement: paso 2, imagen 2 de 3 Acer Aspire One 751h-1948 RAM Card Replacement: paso 2, imagen 3 de 3
    • There are two Phillips #0 (M2-L2.5 mm) screws that is securing the cover. Remove these screws and lift up the cover panel.
  3. Acer Aspire One 751h-1948 RAM Card Replacement: paso 3, imagen 1 de 2 Acer Aspire One 751h-1948 RAM Card Replacement: paso 3, imagen 2 de 2
    • Use your thumbs to push the RAM clips out. The card should lift up when its released. It can then be removed.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 191
