Saltar al contenido principal
Acer Aspire One 725-0845 Touchpad Replacement
Qué necesitas
  1. Acer Aspire One 725-0845 Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Touchpad Replacement: paso 2, imagen 1 de 3 Acer Aspire One 725-0845 Touchpad Replacement: paso 2, imagen 2 de 3 Acer Aspire One 725-0845 Touchpad Replacement: paso 2, imagen 3 de 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: paso 3, imagen 1 de 3 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: paso 3, imagen 2 de 3 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: paso 3, imagen 3 de 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: paso 4, imagen 1 de 2 Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Touchpad Replacement: paso 5, imagen 1 de 1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: paso 6, imagen 1 de 3 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: paso 6, imagen 2 de 3 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: paso 6, imagen 3 de 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Acer Aspire One 725-0845 Touchpad Replacement: paso 7, imagen 1 de 3 Acer Aspire One 725-0845 Touchpad Replacement: paso 7, imagen 2 de 3 Acer Aspire One 725-0845 Touchpad Replacement: paso 7, imagen 3 de 3
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Acer Aspire One 725-0845 Touchpad Replacement: paso 8, imagen 1 de 3 Acer Aspire One 725-0845 Touchpad Replacement: paso 8, imagen 2 de 3 Acer Aspire One 725-0845 Touchpad Replacement: paso 8, imagen 3 de 3
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
  9. Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: paso 9, imagen 1 de 2 Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: paso 9, imagen 2 de 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the 17 screws (3.0 mm) from the back of the keyboard.
  10. Acer Aspire One 725-0845 Touchpad Replacement: paso 10, imagen 1 de 2 Acer Aspire One 725-0845 Touchpad Replacement: paso 10, imagen 2 de 2
    • Remove the keyboard by lifting up and away from the cover/palm rest. Be careful with the keyboard connection during this step.
    • To replace an individual key, remove the key from the keyboard using a plastic opening tool.
  11. Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: paso 11, imagen 1 de 2 Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: paso 11, imagen 2 de 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (7.0 mm) from touchpad buttons.
  12. Acer Aspire One 725-0845 Touchpad Replacement: paso 12, imagen 1 de 2 Acer Aspire One 725-0845 Touchpad Replacement: paso 12, imagen 2 de 2
    • On the cover/palm rest, lift the black locks for the touchpad buttons into the upward position.
    • Remove the connection for the touchpad buttons by gently pulling the purple tabs away from the locks.
    • Remove touchpad buttons by lifting them up and away from the cover/palm rest.
Conclusión
2 personas más completaron esta guía.
Joe Kendall
Miembro Desde 02/15/17
346 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-3, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 1,386
