Saltar al contenido principal
Acer Aspire One 725-0845 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire One 725-0845 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Hard Drive Replacement: paso 2, imagen 1 de 3 Acer Aspire One 725-0845 Hard Drive Replacement: paso 2, imagen 2 de 3 Acer Aspire One 725-0845 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: paso 3, imagen 1 de 3 Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: paso 3, imagen 2 de 3 Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: paso 3, imagen 3 de 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Acer Aspire One 725-0845 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
Conclusión
2 personas más completaron esta guía.
Jose Souto
Miembro Desde 02/15/17
337 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-3, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 1,392
