Introducción
The battery is the power source for the device. A damaged or faulty battery will cause the device to not power on. If you have followed all the steps in the Troubleshooting Guide and found that you have a damaged or faulty battery, this step-by-step guide will lead you through the process of removing and replacing the battery.
Qué necesitas
Ensure the device is powered off by holding down the power button on the top left-hand side.
On a flat, level surface, flip the device over so that the back-plate is accessible.
2 personas más completaron esta guía.
