Saltar al contenido principal
Acer Aspire One 722 Screen Replacement
Qué necesitas
  1. Acer Aspire One 722 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Screen Replacement: paso 2, imagen 1 de 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Screen Replacement: paso 3, imagen 1 de 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Screen Replacement: paso 4, imagen 1 de 2 Acer Aspire One 722 Screen Replacement: paso 4, imagen 2 de 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Screen Replacement: paso 5, imagen 1 de 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Screen Replacement, Screen: paso 6, imagen 1 de 2 Acer Aspire One 722 Screen Replacement, Screen: paso 6, imagen 2 de 2
    • Remove the black rubber clips from the bottom right and left of the netbook screen.
  7. Acer Aspire One 722 Screen Replacement: paso 7, imagen 1 de 2 Acer Aspire One 722 Screen Replacement: paso 7, imagen 2 de 2
    • Remove the screws under the black caps.
  8. Acer Aspire One 722 Screen Replacement: paso 8, imagen 1 de 3 Acer Aspire One 722 Screen Replacement: paso 8, imagen 2 de 3 Acer Aspire One 722 Screen Replacement: paso 8, imagen 3 de 3
    • Slowly separate the screen casing from the screen.
    • Potential for device damage: Be careful when detaching the screen casing from the screen. If not done slowly, it can break.
  9. Acer Aspire One 722 Screen Replacement: paso 9, imagen 1 de 3 Acer Aspire One 722 Screen Replacement: paso 9, imagen 2 de 3 Acer Aspire One 722 Screen Replacement: paso 9, imagen 3 de 3
    • Remove the screws located on the four corners of the screen.
  10. Acer Aspire One 722 Screen Replacement: paso 10, imagen 1 de 3 Acer Aspire One 722 Screen Replacement: paso 10, imagen 2 de 3 Acer Aspire One 722 Screen Replacement: paso 10, imagen 3 de 3
    • Remove the two bottom screws.
    • Taking out these screws will allow you to remove the screen from its attachment.
  11. Acer Aspire One 722 Screen Replacement: paso 11, imagen 1 de 3 Acer Aspire One 722 Screen Replacement: paso 11, imagen 2 de 3 Acer Aspire One 722 Screen Replacement: paso 11, imagen 3 de 3
    • On the bottom left of the screen there is a cord attached. Remove the tape that is attached to the screen.
  12. Acer Aspire One 722 Screen Replacement: paso 12, imagen 1 de 3 Acer Aspire One 722 Screen Replacement: paso 12, imagen 2 de 3 Acer Aspire One 722 Screen Replacement: paso 12, imagen 3 de 3
    • On the green board, remove the two screws.
    • Remove the board.
Conclusión
4 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 16
Todo El Tiempo: 3,383
