Saltar al contenido principal
Acer Aspire One 532h-2806 Screen Replacement
Qué necesitas
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: paso 1, imagen 1 de 2 Acer Aspire One 532h-2806 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: paso 2, imagen 1 de 2 Acer Aspire One 532h-2806 Screen Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: paso 3, imagen 1 de 2 Acer Aspire One 532h-2806 Screen Replacement: paso 3, imagen 2 de 2
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: paso 4, imagen 1 de 3 Acer Aspire One 532h-2806 Screen Replacement: paso 4, imagen 2 de 3 Acer Aspire One 532h-2806 Screen Replacement: paso 4, imagen 3 de 3
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: paso 5, imagen 1 de 1
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: paso 6, imagen 1 de 1
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: paso 7, imagen 1 de 2 Acer Aspire One 532h-2806 Screen Replacement: paso 7, imagen 2 de 2
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: paso 8, imagen 1 de 3 Acer Aspire One 532h-2806 Screen Replacement: paso 8, imagen 2 de 3 Acer Aspire One 532h-2806 Screen Replacement: paso 8, imagen 3 de 3
    • Remove the screen.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 318
