Saltar al contenido principal
Acer Aspire One 532h-2806 Keyboard Replacement
Qué necesitas
  1. Acer Aspire One 532h-2806 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Make sure the laptop is turned off and the battery is removed.
    • Above the top row of the keys, locate three plastic latches.
  2. Acer Aspire One 532h-2806 Keyboard Replacement: paso 2, imagen 1 de 1
    • Use the medal spudger to press each tab. The keyboard should release.
    • Slide the spudger, so that the tabs do not reset after pressing each one.
  3. Acer Aspire One 532h-2806 Keyboard Replacement: paso 3, imagen 1 de 1
    • Gently lift the keyboard up.
    • The keyboard ribbon cable is still attached to the motherboard.
  4. Acer Aspire One 532h-2806 Keyboard Replacement: paso 4, imagen 1 de 1
    • Carefully unplug the connector sticker on the back of the keyboard.
    • Be gentle, do not force it out.
  5. Acer Aspire One 532h-2806 Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove the keyboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 383
