Saltar al contenido principal
Acer Aspire M5-583P-9688 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire M5-583P-9688 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  2. Acer Aspire M5-583P-9688 Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire M5-583P-9688 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Hard Drive Replacement: paso 3, imagen 1 de 2 Acer Aspire M5-583P-9688 Hard Drive Replacement: paso 3, imagen 2 de 2
    • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
    • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 1,577
