Saltar al contenido principal
Acer Aspire M5-583P-9688 Fan Replacement
Qué necesitas
  1. Acer Aspire M5-583P-9688 Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Remove all 18 of the marked screws (2.12 mm) using a Phillips #1 Screwdriver.
  2. Acer Aspire M5-583P-9688 Fan Replacement: paso 2, imagen 1 de 2 Acer Aspire M5-583P-9688 Fan Replacement: paso 2, imagen 2 de 2
    • Use the spudger to slowly and gently work your away around the device, popping the bottom cover off the device.
  3. Acer Aspire M5-583P-9688 Fan Replacement: paso 3, imagen 1 de 2 Acer Aspire M5-583P-9688 Fan Replacement: paso 3, imagen 2 de 2
    • Remove the four marked screws (2.31mm) using a Phillips #1 Screwdriver.
  4. Acer Aspire M5-583P-9688 Fan Replacement: paso 4, imagen 1 de 2 Acer Aspire M5-583P-9688 Fan Replacement: paso 4, imagen 2 de 2
    • After the screws are removed, you will need to unplug it from the motherboard shown by the red rectangle. After it is unplugged, then you will be able to remove the fan completely.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 360
