Saltar al contenido principal
Acer Aspire M5-583P-9688 Battery Replacement
Qué necesitas
  1. Acer Aspire M5-583P-9688 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all 18 marked screws (2.12 mm) using a Phillips #1 Screwdriver.
  2. Acer Aspire M5-583P-9688 Battery Replacement: paso 2, imagen 1 de 2 Acer Aspire M5-583P-9688 Battery Replacement: paso 2, imagen 2 de 2
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Battery Replacement: paso 3, imagen 1 de 2 Acer Aspire M5-583P-9688 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver.
  4. Acer Aspire M5-583P-9688 Battery Replacement: paso 4, imagen 1 de 2 Acer Aspire M5-583P-9688 Battery Replacement: paso 4, imagen 2 de 2
    • Unplug the marked plug from the motherboard and this will complete the removal of the battery.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 2,523
