Introducción
This guide will lead you through the steps of replacing your screen on your Acer Aspier ES1-711-P1UV. The screen may need to be replaced if you are having issues seeing images on the screen.
Qué necesitas
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
Place the laptop on a flat surface and open it to see the screen.
Using your fingers or a plastic opening tool, pry open the bezel that holds the screen in place.
Una persona más ha completado esta guía.
