Saltar al contenido principal
Acer Aspire ES1-711-P1UV Fan Replacement
Qué necesitas
  1. Acer Aspire ES1-711-P1UV Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Fan Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Fan Replacement: paso 3, imagen 1 de 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Fan Replacement: paso 4, imagen 1 de 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Fan Replacement, Fan: paso 5, imagen 1 de 1
    • Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
    • Unscrew the four 5mm screws still holding down the fan.
    • The four 5mm screws in the second part of this step cannot be fully removed from the fan. Loosen them and continue on to Step 6.
  6. Acer Aspire ES1-711-P1UV Fan Replacement: paso 6, imagen 1 de 3 Acer Aspire ES1-711-P1UV Fan Replacement: paso 6, imagen 2 de 3 Acer Aspire ES1-711-P1UV Fan Replacement: paso 6, imagen 3 de 3
    • Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them.
    • Remove the fan assembly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 656
