Saltar al contenido principal
Acer Aspire ES1-711-P1UV Battery Replacement
Qué necesitas
  1. Acer Aspire ES1-711-P1UV Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Battery Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Battery Replacement: paso 3, imagen 1 de 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
Conclusión
4 personas más completaron esta guía.
2 comentarios
Excellent instructions, Thxz.
jmarquez_cruz - Contestar
Wuen i reassemble my laptop doesnt power on…
mk Bane - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 4,159
