Introducción
You may need to replace the fan in your Acer Aspire ES1-512-C80E if you experience problems such overheating or loud noises. To do this, you will need Phillips #00/#000 screwdrivers, and a spudger. Additionally, you will need a replacement fan. To access the fan, the back cover of the device will need to be removed. The process of replacing the fan should take between 15-25 minutes.
Qué necesitas
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
Using a spudger, go around the edges and pry off the keyboard.
Remove twelve 1.2mm Phillips #000 screws from the motherboard, wireless LAN card, and hard drive.
2 personas más completaron esta guía.
