Saltar al contenido principal
Acer Aspire ES1-512-C80E Fan Replacement
Qué necesitas
  1. Acer Aspire ES1-512-C80E Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Fan Replacement: paso 2, imagen 1 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 2, imagen 2 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 2, imagen 3 de 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: paso 3, imagen 1 de 3 Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: paso 3, imagen 2 de 3 Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: paso 3, imagen 3 de 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Fan Replacement: paso 4, imagen 1 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 4, imagen 2 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 4, imagen 3 de 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Fan Replacement: paso 5, imagen 1 de 2 Acer Aspire ES1-512-C80E Fan Replacement: paso 5, imagen 2 de 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Fan Replacement: paso 6, imagen 1 de 1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Fan Replacement, Fan: paso 7, imagen 1 de 2 Acer Aspire ES1-512-C80E Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Remove twelve 1.2mm Phillips #000 screws from the motherboard, wireless LAN card, and hard drive.
  8. Acer Aspire ES1-512-C80E Fan Replacement: paso 8, imagen 1 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 8, imagen 2 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 8, imagen 3 de 3
    • Using a Phillips #000 screwdriver, remove both 1.2mm screws that hold the fan in place.
  9. Acer Aspire ES1-512-C80E Fan Replacement: paso 9, imagen 1 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 9, imagen 2 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 9, imagen 3 de 3
    • Lift the fan, hard drive, motherboard, and wireless LAN card out of the device.
    • These components are still connected with wires. Remove all plugs that may be attached to other components in order to isolate the group of components.
  10. Acer Aspire ES1-512-C80E Fan Replacement: paso 10, imagen 1 de 1
    • Flip over the motherboard.
    • Remove all three 1.2mm Phillips #00 screws that attach the fan to the motherboard.
  11. Acer Aspire ES1-512-C80E Fan Replacement: paso 11, imagen 1 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 11, imagen 2 de 3 Acer Aspire ES1-512-C80E Fan Replacement: paso 11, imagen 3 de 3
    • The fan and motherboard are still connected with wires. Remove any plugs that may be attaching the components
    • Remove the fan from the motherboard.
Conclusión
2 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 408
