Saltar al contenido principal
Acer Aspire ES1-512-C80E Disk Drive Replacement
Qué necesitas
  1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 2, imagen 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 2, imagen 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 2, imagen 3 de 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: paso 3, imagen 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: paso 3, imagen 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: paso 3, imagen 3 de 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 4, imagen 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 4, imagen 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 4, imagen 3 de 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 5, imagen 1 de 2 Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 5, imagen 2 de 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Disk Drive Replacement: paso 6, imagen 1 de 1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: paso 7, imagen 1 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: paso 7, imagen 2 de 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: paso 7, imagen 3 de 3
    • Push the disk drive out of the side slot.
Conclusión
To reassemble your device, follow the steps in reverse order.
Una persona más ha completado esta guía.
Peter Bulman
Miembro Desde 10/31/19
231 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 Miembro de UMass Dartmouth, Team S2-G8, Barthe Fall 2019
UMASSD-BARTHE-F19S2G8
Miembros de 3
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 499
