Saltar al contenido principal
Acer Aspire ES1-512-C80E Battery Replacement
Qué necesitas
  1. Acer Aspire ES1-512-C80E Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Battery Replacement: paso 2, imagen 1 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 2, imagen 2 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 2, imagen 3 de 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: paso 3, imagen 1 de 3 Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: paso 3, imagen 2 de 3 Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: paso 3, imagen 3 de 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Battery Replacement: paso 4, imagen 1 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 4, imagen 2 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 4, imagen 3 de 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Battery Replacement: paso 5, imagen 1 de 2 Acer Aspire ES1-512-C80E Battery Replacement: paso 5, imagen 2 de 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Battery Replacement: paso 6, imagen 1 de 1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Battery Replacement, Battery: paso 7, imagen 1 de 3 Acer Aspire ES1-512-C80E Battery Replacement, Battery: paso 7, imagen 2 de 3 Acer Aspire ES1-512-C80E Battery Replacement, Battery: paso 7, imagen 3 de 3
    • Remove the two 1.2mm Phillips #00 screws securing the battery.
  8. Acer Aspire ES1-512-C80E Battery Replacement: paso 8, imagen 1 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 8, imagen 2 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 8, imagen 3 de 3
    • Use a nylon spudger to remove the battery from the clips that hold it down.
  9. Acer Aspire ES1-512-C80E Battery Replacement: paso 9, imagen 1 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 9, imagen 2 de 3 Acer Aspire ES1-512-C80E Battery Replacement: paso 9, imagen 3 de 3
    • Remove the wired connection to the laptop by pulling the plug out of the motherboard.
    • Remove the battery from the laptop.
Conclusión
2 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 10
Ultimos 30 días: 27
Todo El Tiempo: 1,987
