Saltar al contenido principal
Acer Aspire E5-721-64T8 Motherboard Replacement
Qué necesitas
  1. Acer Aspire E5-721-64T8 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove the two 6mm J0 screws located in the right and left side of the battery.
    • Make sure to unplug of disconnect the power cable before removing the battery.
  2. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 2, imagen 1 de 2 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the connector from the motherboard.
  3. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 3, imagen 1 de 3 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 3, imagen 2 de 3 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the two 6mm Phillips J0 screws located in the right and left side of heatsink mounts.
    • Remove the four 6mm Phillips J0 screws located on the heatsink power mount.
    • Lift and remove heatsink from motherboard completely.
  4. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 4, imagen 1 de 2 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove wi-fi card by pulling from socket.
  5. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove screen connector by pulling it upwards.
  6. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove speaker connector from the motherboard by pulling on the tab.
  7. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 7, imagen 1 de 3 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 7, imagen 2 de 3 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove the four blue tabbed ribbon connectors to the motherboard by lifting white clamps and pulling out connector.
  8. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 8, imagen 1 de 2 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove black ribbon connector by lifting white clamp and pulling connector out.
  9. Acer Aspire E5-721-64T8 Motherboard Replacement: paso 9, imagen 1 de 2 Acer Aspire E5-721-64T8 Motherboard Replacement: paso 9, imagen 2 de 2
    • Finally lift motherboard from narrow side and jiggle it out so all ports going through the laptop case on the left slide out.
Conclusión
Ed Herrera
Miembro Desde 01/25/18
390 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S7-G3, Passmore Spring 2018 Miembro de USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 159
