Saltar al contenido principal
Acer Aspire E5-573G Fan Replacement
Qué necesitas
  1. Acer Aspire E5-573G Fan  Replacement, Fan: paso 1, imagen 1 de 2 Acer Aspire E5-573G Fan  Replacement, Fan: paso 1, imagen 2 de 2
    • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
    • Be sure to unplug and power down your computer before starting any work.
  2. Acer Aspire E5-573G Fan  Replacement: paso 2, imagen 1 de 2 Acer Aspire E5-573G Fan  Replacement: paso 2, imagen 2 de 2
    • Remove the CD drive located on the side of the laptop.
  3. Acer Aspire E5-573G Fan  Replacement: paso 3, imagen 1 de 1
    • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
  4. Acer Aspire E5-573G Fan  Replacement: paso 4, imagen 1 de 3 Acer Aspire E5-573G Fan  Replacement: paso 4, imagen 2 de 3 Acer Aspire E5-573G Fan  Replacement: paso 4, imagen 3 de 3
    • Use the spudger to pry open the back cover by sliding it along the sides.
    • Slowly lift the cover upwards.
    • Be gentle while removing the case as it is very thin and might break easily.
  5. Acer Aspire E5-573G Fan  Replacement: paso 5, imagen 1 de 2 Acer Aspire E5-573G Fan  Replacement: paso 5, imagen 2 de 2
    • Apply canned air or use a bellows to remove the dust on the motherboard.
    • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
    • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
  6. Acer Aspire E5-573G Fan  Replacement: paso 6, imagen 1 de 3 Acer Aspire E5-573G Fan  Replacement: paso 6, imagen 2 de 3 Acer Aspire E5-573G Fan  Replacement: paso 6, imagen 3 de 3
    • Lift out the fan and detach the fan cable from the motherboard.
    • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
Conclusión
Una persona más ha completado esta guía.
Lara Mustafa
Miembro Desde 01/08/21
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 842
