Saltar al contenido principal
Acer Aspire E5-571P-55TL Motherboard Replacement
Qué necesitas
  1. Acer Aspire E5-571P-55TL Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 2, imagen 1 de 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 3, imagen 1 de 2 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 3, imagen 2 de 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Motherboard Replacement, Keyboard: paso 4, imagen 1 de 2 Acer Aspire E5-571P-55TL Motherboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 5, imagen 1 de 3 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 5, imagen 2 de 3 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 5, imagen 3 de 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL Motherboard Replacement, CPU Fan: paso 6, imagen 1 de 2 Acer Aspire E5-571P-55TL Motherboard Replacement, CPU Fan: paso 6, imagen 2 de 2
    • Before replacing the CPU fan, you'll have to remove the network card found below the fan.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
    • Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
  7. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 7, imagen 1 de 2 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 7, imagen 2 de 2
    • The CPU fan can be found in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws from the fan.
  8. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 8, imagen 1 de 2 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to safely remove the fan plug from the motherboard. To remove the plug, gently push left.
  9. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 9, imagen 1 de 1
    • Make sure that all fan wires are disconnected from the board.
    • Lift the curved end of the fan, and safely remove it.
  10. Acer Aspire E5-571P-55TL Motherboard Replacement, Hard Drive: paso 10, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  11. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 11, imagen 1 de 2 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 11, imagen 2 de 2
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  12. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 12, imagen 1 de 1
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
  13. Acer Aspire E5-571P-55TL Motherboard Replacement, Motherboard: paso 13, imagen 1 de 2 Acer Aspire E5-571P-55TL Motherboard Replacement, Motherboard: paso 13, imagen 2 de 2
    • With a Phillips #0 screwdriver, remove the two 4 mm screws from the motherboard.
  14. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 14, imagen 1 de 3 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 14, imagen 2 de 3 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 14, imagen 3 de 3
    • Carefully disconnect the speaker connection to the motherboard.
  15. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 15, imagen 1 de 3 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 15, imagen 2 de 3 Acer Aspire E5-571P-55TL Motherboard Replacement: paso 15, imagen 3 de 3
    • The last connection to the motherboard is the screen. Gently disconnect the cable from the motherboard.
  16. Acer Aspire E5-571P-55TL Motherboard Replacement: paso 16, imagen 1 de 1
    • Lift the motherboard up from the top right corner, and then pull it right to release it from the case.
Conclusión
Max Piekos
Miembro Desde 03/23/22
459 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 347
