Saltar al contenido principal
Acer Aspire E5-571-58CG Power Jack Replacement
Qué necesitas
  1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Power Jack Replacement: paso 2, imagen 1 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: paso 2, imagen 2 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: paso 2, imagen 3 de 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: paso 3, imagen 1 de 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: paso 3, imagen 2 de 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: paso 3, imagen 3 de 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Power Jack Replacement: paso 4, imagen 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: paso 4, imagen 2 de 2
    • Remove the plastic safeguard from the CD drive slot.
  5. Acer Aspire E5-571-58CG Power Jack Replacement: paso 5, imagen 1 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: paso 5, imagen 2 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: paso 5, imagen 3 de 3
    • Remove the marked screws with the JIS #00 screwdriver.
  6. Acer Aspire E5-571-58CG Power Jack Replacement: paso 6, imagen 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: paso 6, imagen 2 de 2
    • Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
  7. Acer Aspire E5-571-58CG Power Jack Replacement: paso 7, imagen 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: paso 7, imagen 2 de 2
    • Lift the bottom right side of the screen to move the metal plate covering the power jack.
  8. Acer Aspire E5-571-58CG Power Jack Replacement: paso 8, imagen 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: paso 8, imagen 2 de 2
    • Carefully lift the power jack out of the laptop.
Conclusión
Una persona más ha completado esta guía.
Aliana Johnson
Miembro Desde 10/24/18
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 1,243
