Saltar al contenido principal
Acer Aspire E5-571-58CG CPU Fan Replacement
Qué necesitas
  1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG CPU Fan Replacement: paso 2, imagen 1 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: paso 2, imagen 2 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: paso 2, imagen 3 de 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: paso 3, imagen 1 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: paso 3, imagen 2 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: paso 3, imagen 3 de 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG CPU Fan Replacement: paso 4, imagen 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement: paso 4, imagen 2 de 2
    • Use a JIS #000 screw bit to remove the marked screw.
  5. Acer Aspire E5-571-58CG CPU Fan Replacement: paso 5, imagen 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement: paso 5, imagen 2 de 2
    • Carefully pull the marked green chip out of the motherboard.
  6. Acer Aspire E5-571-58CG CPU Fan Replacement: paso 6, imagen 1 de 2 Acer Aspire E5-571-58CG CPU Fan Replacement: paso 6, imagen 2 de 2
    • Use tweezers to unplug the wire connecting the fan to the motherboard.
  7. Acer Aspire E5-571-58CG CPU Fan Replacement: paso 7, imagen 1 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: paso 7, imagen 2 de 3 Acer Aspire E5-571-58CG CPU Fan Replacement: paso 7, imagen 3 de 3
    • Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
    • Carefully remove the CPU fan.
Conclusión
Brendan Cuthill
Miembro Desde 10/29/18
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 295
