Saltar al contenido principal
Acer Aspire E5-571 WiFi Replacement
Qué necesitas
  1. Acer Aspire E5-571 WiFi Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 WiFi Replacement: paso 2, imagen 1 de 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 WiFi Replacement: paso 3, imagen 1 de 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 WiFi Replacement, Keyboard: paso 4, imagen 1 de 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 WiFi Replacement: paso 5, imagen 1 de 3 Acer Aspire E5-571 WiFi Replacement: paso 5, imagen 2 de 3 Acer Aspire E5-571 WiFi Replacement: paso 5, imagen 3 de 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 WiFi Replacement: paso 6, imagen 1 de 2 Acer Aspire E5-571 WiFi Replacement: paso 6, imagen 2 de 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 WiFi Replacement, WiFi: paso 7, imagen 1 de 1
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 WiFi Replacement: paso 8, imagen 1 de 2 Acer Aspire E5-571 WiFi Replacement: paso 8, imagen 2 de 2
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 WiFi Replacement: paso 9, imagen 1 de 3 Acer Aspire E5-571 WiFi Replacement: paso 9, imagen 2 de 3 Acer Aspire E5-571 WiFi Replacement: paso 9, imagen 3 de 3
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
Conclusión
9 personas más completaron esta guía.
daniel sawyer
Miembro Desde 08/23/15
2,566 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-2, Meier Fall 2015 Miembro de USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Miembros
5 Guías creadas
7 comentarios
Very well done - thank you!
glgsolutions - Contestar
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
daniel sawyer -
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Dan O - Contestar
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Patrizia Barberio - Contestar
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 7,530
