Saltar al contenido principal
Acer Aspire E5-511p-C6US RAM Replacement
Qué necesitas
  1. Acer Aspire E5-511p-C6US RAM Replacement, Battery: paso 1, imagen 1 de 3 Acer Aspire E5-511p-C6US RAM Replacement, Battery: paso 1, imagen 2 de 3 Acer Aspire E5-511p-C6US RAM Replacement, Battery: paso 1, imagen 3 de 3
    • On the back of the laptop, there is a sliding lock. Push the slider and the battery will unlock
  2. Acer Aspire E5-511p-C6US RAM Replacement: paso 2, imagen 1 de 1
    • Pull battery to remove.
  3. Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: paso 3, imagen 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: paso 3, imagen 2 de 2
    • Remove the 1 screw just above the battery with a Phillips #1 screwdriver.
  4. Acer Aspire E5-511p-C6US RAM Replacement: paso 4, imagen 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement: paso 4, imagen 2 de 2
    • Pull the Optical Drive out
  5. Acer Aspire E5-511p-C6US RAM Replacement, Keyboard: paso 5, imagen 1 de 1
    • Remove the 17 Phillips #1 screws remaining on the back side of the laptop
  6. Acer Aspire E5-511p-C6US RAM Replacement: paso 6, imagen 1 de 3 Acer Aspire E5-511p-C6US RAM Replacement: paso 6, imagen 2 de 3 Acer Aspire E5-511p-C6US RAM Replacement: paso 6, imagen 3 de 3
    • Flip over the laptop, Using the spudger separate the body of the keyboard from the base of the laptop.
  7. Acer Aspire E5-511p-C6US RAM Replacement: paso 7, imagen 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement: paso 7, imagen 2 de 2
    • Carefully lift the keyboard and disconnect the 3 ribbon style connectors from the computers boards.
  8. Acer Aspire E5-511p-C6US RAM Replacement, Fan: paso 8, imagen 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement, Fan: paso 8, imagen 2 de 2
    • Disconnect the cord from the fan
  9. Acer Aspire E5-511p-C6US RAM Replacement: paso 9, imagen 1 de 1
    • Remove the 2 #1 Phillips screws
  10. Acer Aspire E5-511p-C6US RAM Replacement: paso 10, imagen 1 de 1
    • now the fan can be pulled from the laptop
  11. Acer Aspire E5-511p-C6US RAM Replacement, RAM: paso 11, imagen 1 de 1
    • Disconnect the 2 plugs remaining on the computer
  12. Acer Aspire E5-511p-C6US RAM Replacement: paso 12, imagen 1 de 1
    • Remove the last 2 #1 Philips screws from the body
  13. Acer Aspire E5-511p-C6US RAM Replacement: paso 13, imagen 1 de 1
    • Remove the 2 #1 Phillips screws, then slide the metal cover back and away
  14. Acer Aspire E5-511p-C6US RAM Replacement: paso 14, imagen 1 de 1
    • Remove the board from the laptop body, flip over for access to the ram
  15. Acer Aspire E5-511p-C6US RAM Replacement: paso 15, imagen 1 de 2 Acer Aspire E5-511p-C6US RAM Replacement: paso 15, imagen 2 de 2
    • Press down on the spring clips on either side of the ram, It will unlock and can be removed
Conclusión
Aaron
Miembro Desde 03/19/18
562 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 662
