Saltar al contenido principal
Acer Aspire E3-111-C0WA Battery Replacement
Qué necesitas
  1. Acer Aspire E3-111-C0WA Battery Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire E3-111-C0WA Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Battery Replacement: paso 2, imagen 1 de 3 Acer Aspire E3-111-C0WA Battery Replacement: paso 2, imagen 2 de 3 Acer Aspire E3-111-C0WA Battery Replacement: paso 2, imagen 3 de 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Battery Replacement: paso 3, imagen 1 de 2 Acer Aspire E3-111-C0WA Battery Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Battery Replacement: paso 4, imagen 1 de 3 Acer Aspire E3-111-C0WA Battery Replacement: paso 4, imagen 2 de 3 Acer Aspire E3-111-C0WA Battery Replacement: paso 4, imagen 3 de 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Battery Replacement: paso 5, imagen 1 de 2 Acer Aspire E3-111-C0WA Battery Replacement: paso 5, imagen 2 de 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Battery Replacement: paso 6, imagen 1 de 2 Acer Aspire E3-111-C0WA Battery Replacement: paso 6, imagen 2 de 2
    • Lift the battery up and off the rest of the laptop.
Conclusión
Jackson Li
Miembro Desde 10/17/17
101 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,164
