Saltar al contenido principal
Acer Aspire E1-572-6829 Wi-Fi Card Replacement
Qué necesitas
  1. Acer Aspire E1-572-6829 Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Before beginning, make sure the laptop is turned off and the charger is unplugged.
    • Flip the laptop over so that you are facing the back panel.
    • Locate the battery lock switch below the battery.
  2. Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 2, imagen 1 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 2, imagen 2 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 2, imagen 3 de 3
    • Slide the battery lock switch to the open position using your finger or a plastic spudger.
    • While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
    • Your battery is removed. You can now let go of the lock switch.
    • To reinsert the battery, make sure that it's tabs are lined up with the laptop and that it is facing in the right direction. Then slide it straight back in without using the lock switch.
  3. Acer Aspire E1-572-6829 Wi-Fi Card Replacement, Keyboard and Touchpad Assembly: paso 3, imagen 1 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement, Keyboard and Touchpad Assembly: paso 3, imagen 2 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement, Keyboard and Touchpad Assembly: paso 3, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the seventeen 8 mm screws that secure the back panel.
    • Use a plastic spudger to pry open the lower back panel from its top edge.
    • Lift the panel up and out to remove it.
  4. Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 4, imagen 1 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 4, imagen 2 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 8 mm screws on the inner side of the lower back panel.
    • Use the pull tab on the left side of the 2.5 inch hard disk tray to slide it out of the SATA port.
    • The hard disk along with the 2.5 inch tray can now be safely removed.
  5. Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 5, imagen 1 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 5, imagen 2 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 5, imagen 3 de 3
    • Flip the laptop over and open the lid so that the keyboard side is facing upwards.
    • Use a plastic pry tool to pry open the tabs holding the top panel on around all sides of the laptop.
    • Once all the tabs are free, carefully lift up the top panel to open it slightly.
    • Do not lift the top panel up too much or with excessive force since there are delicate ribbon cables on the inside that need to be disconnected before the assembly can be detached.
  6. Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 6, imagen 1 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 6, imagen 2 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 6, imagen 3 de 3
    • Carefully detach the 3 ribbon cables connecting the top panel to the motherboard.
    • Be careful when removing the ribbon cables. Some of the connectors might have small plastic tabs that need to be lifted up before the cable can be detached.
    • The 3 ribbon cables from left to right correspond to the power button, the touch-pad, and the keyboard respectively.
  7. Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 7, imagen 1 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 7, imagen 2 de 3 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 7, imagen 3 de 3
    • Once the ribbon cables are detached, the entire top panel consisting of the keyboard and the touch-pad assembly can safely be removed from the laptop.
  8. Acer Aspire E1-572-6829 Wi-Fi Card Replacement, Wi-Fi Card: paso 8, imagen 1 de 2 Acer Aspire E1-572-6829 Wi-Fi Card Replacement, Wi-Fi Card: paso 8, imagen 2 de 2
    • Detach the two cables connected to the Wi-Fi card. Gently pull them off using a plastic pry tool or your fingers.
    • To reinsert the cables, push them back onto the connecting points. Make sure that you orient them on the same side you disconnected them from.
  9. Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 9, imagen 1 de 2 Acer Aspire E1-572-6829 Wi-Fi Card Replacement: paso 9, imagen 2 de 2
    • Unscrew and remove the one 5 mm Phillips #0 screw that secures the Wi-Fi card.
    • Carefully lift up the Wi-Fi card and pull it up and out to remove it.
Conclusión
Anamika Menon
Miembro Desde 03/13/23
493 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 243
