Saltar al contenido principal
Acer Aspire E1-532-2616 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire E1-532-2616 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 Acer Aspire E1-532-2616 Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Use a Phillips screwdriver to remove the CM2.5*3 screw on the shown cover.
    • Lift and remove the cover from the side that had the holdinging screw.
    • Lifting the plastic cover will require some pressure.
  2. Acer Aspire E1-532-2616 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Unscrew the two CM2*3-4 screws that attach the hard drive to the Laptop.
  3. Acer Aspire E1-532-2616 Hard Drive Replacement: paso 3, imagen 1 de 2 Acer Aspire E1-532-2616 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Push the hard drive away from where the screws were (to the left, if referring to the picture).
    • The hard drive will slide to the left, allowing it to be safely removed.
Conclusión
Un comentario
Hello! Is it possible to recover data from it? My laptop is dead and I don't know how I could recover my files.. I'm not good in computers :D thank you in advance!
Andri HaiHui - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 2,119
