Saltar al contenido principal
Acer Aspire E1-531-2438 RAM Replacement
Qué necesitas
  1. Acer Aspire E1-531-2438 RAM Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire E1-531-2438 RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 RAM Replacement: paso 2, imagen 1 de 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 RAM Replacement, RAM: paso 3, imagen 1 de 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: paso 3, imagen 2 de 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: paso 3, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  4. Acer Aspire E1-531-2438 RAM Replacement: paso 4, imagen 1 de 3 Acer Aspire E1-531-2438 RAM Replacement: paso 4, imagen 2 de 3 Acer Aspire E1-531-2438 RAM Replacement: paso 4, imagen 3 de 3
    • Gently press outward on the two tabs that lock the RAM module in place.
    • Once the RAM module releases and flips up, gently pull the RAM module directly out of its socket.
Conclusión
Jakob Rinkus
Miembro Desde 03/21/19
965 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 554
