Introducción
Computer slow or crashing, making grinding noises when running. This guide will show you how to remove and replace the Hard Drive on your Acer Aspire E1-531-2438.
Qué necesitas
Turn the device over so the back side is facing up.
Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
Una persona más ha completado esta guía.
