Saltar al contenido principal
Acer Aspire E1-531-2438 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire E1-531-2438 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire E1-531-2438 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Acer Aspire E1-531-2438 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Hard Drive Replacement: paso 4, imagen 1 de 3 Acer Aspire E1-531-2438 Hard Drive Replacement: paso 4, imagen 2 de 3 Acer Aspire E1-531-2438 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  5. Acer Aspire E1-531-2438 Hard Drive Replacement: paso 5, imagen 1 de 3 Acer Aspire E1-531-2438 Hard Drive Replacement: paso 5, imagen 2 de 3 Acer Aspire E1-531-2438 Hard Drive Replacement: paso 5, imagen 3 de 3
    • Grip the plastic tab on the hard drive, then pull to the left to unplug the drive from its socket.
    • Once free from the socket, lift the hard drive up and out of the device.
Conclusión
Una persona más ha completado esta guía.
Jakob Rinkus
Miembro Desde 03/21/19
965 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 14
Ultimos 30 días: 33
Todo El Tiempo: 1,965
