Saltar al contenido principal
Acer Aspire E1-510P-4637 Touch Screen Display Replacement
Qué necesitas
  1. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Battery: paso 1, imagen 1 de 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 2, imagen 1 de 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: paso 3, imagen 1 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: paso 3, imagen 2 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: paso 3, imagen 3 de 3
    • Remove the plastic screw covers located near the laptop's hinge using a metal spudger.
    • Remove the two M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  4. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 4, imagen 1 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 4, imagen 2 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 4, imagen 3 de 3
    • Flip the laptop over and open it up so the screen is facing up and the top of the screen is facing you.
    • Use a plastic opening tool to separate the the touchscreen from the back cover.
    • Carefully work your way around the frame and gently pry. Be careful not to brake the frame or damage the screen.
  5. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 5, imagen 1 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 5, imagen 2 de 3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 5, imagen 3 de 3
    • Disconnect the display cable by first taking off the tape using a metal spudger and then pulling on the black tab.
  6. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 6, imagen 1 de 2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 6, imagen 2 de 2
    • Take off the yellow tape connecting the display to the border.
  7. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 7, imagen 1 de 2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 7, imagen 2 de 2
    • Pull back the adhesive using the metal spudger.
    • Pry out the camera by lifting the adhesive with the metal spudger. Then, remove the camera by lifting it up by one side.
  8. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 8, imagen 1 de 1
    • Remove the two brackets holding the displays by unscrewing both M1 .6x3 screws with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: paso 9, imagen 1 de 1
    • Release the display from the border using your hands.
Conclusión
2 personas más completaron esta guía.
Caleb lindsay
Miembro Desde 04/11/16
778 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 34-15, Maness Spring 2016 Miembro de Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Miembros
6 Guías creadas
Un comentario
the touchscreen its glue together with the LCD?
Chris Foliaki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 1,197
